1 - 7 of 7 Posts
· Banned
After installing a new battery my check engine light came on, It's a 98 4 runner 4 cyl. 2 w/d automatic, Can anyone tell me how to shut it off. I checked all the codes and nothing comes up with a problem.
Thanks in advance.
· Banned
I went to autozone they said all the codes came up ok, But he told me to take it to toyota to get the light turned off, I remmember in one of my last toyota's I could turn on the key pump the gas peddle a few times then turn off the key and then re start the truck and the light would be off, But I can't remember how many times to pump the gas or if that will even work with this 4 runner.
· Banned
OOPs disconnecting the battery and reconnecting it worked for about 2 days and the check engine light is back on, I'm going to try removing and re-seating the EFI fuse (IIRC). now and see what happens, I'm keeping my fingers crossed. Update to follow. Normally that light is due to a smog equipment problem right?
1 - 7 of 7 Posts
