Can't find a DYI, please help.
Can't remove the silver part where our shifter sticks out of. Painting the dash, got the top part off but not the lower part.
Thanks all.
Thanks all.
Have you removed the cup holders yet? Once those are removed there is a small screw that holds the piece that you are referring to in place. Once you remove that, you need to put the truck in drive and then you can slide that piece back towards you and then lift it off.
^Yep. Once the screw is removed, it's very simple to slide out. Good advice on putting the shifter in drive before yanking on it :)
Good idea on moveing to drive or unscrew and then take off
