Picked up a 2000 Tundra that's been sitting a while and I've changed the oil but nothing else yet. When I put in drive it shifts a little hard so trans fluid & filter swap is planned, but after it's in gear it doesn't want to give it all the gas I'm asking for via the pedal. If I'm on the gas even half throttle, the RPMs rise a little and the whole truck will vibrate sorta, and then it'll eventually shift or catch up.
Noticed today the rear end is leaking a bit so I'm going to drain and fill that so I can try to keep track of where it's leaking from but is that the issue or is it trans related?
