We have the Martin Garage door and opener. Does home link work with it?
I did a search couldnt find anything even on homelinks web.
Anyone have a Martin door with homelink?
You may need to contact a Martin dealer about this. I had to do something different to my door opener and home link to get it to work. I don't have a Martin opener, but I had to push the button on my opener and within 30 seconds push the home link button and it worked fine.
My door opener uses rolling codes, so after I set the homelink with my remote, I had to push the "learn code" button on the opener then press the homelink twice (per instructions on my opener). Now it works just fine.
is there anyway of knowing if your door uses a certain type of code or just trial and error?
After several tries I was able to program my Martin Garage Door to open with homelink. First reset by pressing first and third button till rapidly blinking. approx 20 sec.
I first tried the first button and the door opener but did not work. I tried it several times. Then I decided to try the middle button with the opener and that worked. I opened/closed several times and it works. I called Martin Garage Door and they said that if I wanted a tech to come out it would be $39 trip charge. That got me going to get it done myself.
In a website that I found regarding Martin Doors. This would only work with 315MHz controller.
http://www.martindoor.com/Company-Info/FAQs.aspx
Of course begin with installing fresh battery.
