I just changed my Tundras brake fluid today, I used dot 3 synthetic.
I purchased a hose with a check valve and a hose clamp at AA, the clamp holds the hose to the zerk fitting, its a must to do a one man brake purge. shown on the right of the picture full of five year old brake fluid.
To remove the fluid from the reservoir I made the suction bottle, I drilled two holes on a Pepsi bottle cap, I got some tubing from work, the tubes fit tight one is longer than the other, Cost nada $0, by sucking on the short tube you can quickly draw the fluid out. I have a vacuum pump but wasn't really needed. shown to the left of the picture.
That is new dot fluid in the bottle to compare.
Heres the fluid from my 05 Civic, I think the body shop saves old brake fluid, this car only has 20k it wasn't that dirty till I got it back from the body shop.
