First real issue with my 07' 5.7 SR5 Love the truck, and plan on running until it finally says no...(117K miles) could be a while .... Started by turning the key and getting a CLICK ... turned it off and tried again and she fired right up ... cool ... on my trip home my check engine light came on .... ran by the local auto zone and it had 4 codes .... all refereeing to the Cam position sensor, and crank shaft position sensor ... these are $100 buck a pop .... so mechanic friend said clean ALL battery post and CHECK CHECK CHECK the ground ....had to replace the terminal on the negative wire connecting to the battery ... did that ... the truck had trouble starting ....this was due to the computer resetting .... it had to re-learn ....so it even died on me once around the block..... thinking everything was fixed ... but a week later it did it again ... I had used a cheap, non lead connector on the negative terminal (only thing Oriley had) and my mechanic said that is where he started ... but at this point the clicking had been happening for about 10 days .... on the initial start in the morning .... it would click, I would turn it off and I would get it started ....we did all the fuse box tricks and all the potential connection tips found on this site..... now from not figuring out at the beginning where I had a bad connection, I was sending low voltage through the starter and it could not turn over.... but I would keep trying and trying ... and eventually get it fired .... this is what caused my starter to go out .... YES the labor is a PITA ... and is 5 hrs at a shop for an R&R ... I had to take it in ... there are a bunch of re-man starters out there...and most are made in Mexico ...the OEM cost $500 ... but there is one Re-maed you want! ...BOSH has a re-manned for $200 ish ...it comes with a 24 month warranty .... we had to order ours from 4hrs away ..... with the cost of labor....don't go cheap on your starter. ..... and don't start dropping hundreds on position sensors unless your SURE !!!
