I know this is probably a dumb question, but I have changed the oil twice already on my 2010 cm, and I just wanted to know if I need to somehow grease the carrier bearing that holds up the rear rear driveline. I have always just greased the u joint zurks. Just hoping Im not missing something.
Thanks,
Tony
If it is a 4x4 you will have 3 on the rear shaft and 2 on the front shaft. Not sure about 2 wheel drive. Have heard that 2 wheel drive don't have any but can't confirm.
Sorry 4wd. I just wasnt sure If there were any hidden fittings in that bearing around the yoke that holds the driveline to the frame.
