1 - 10 of 10 Posts
I'd like to put some wheel adapters (spacers) on my factory RW wheels and I was curious how thick I'd need them to be to take the tires flush with the fenders I'm think 1.25" should do it anyone know?
I'd say that 1.25" would be perfect! In fact, I'm about to list my set (which I used for less than 2000 miles cause I got new rims) in the Classifieds. I paid $180/shipped, and I'll probably list them for half that, shipping included ($90). I'm away from home until Monday, so I'll take pics & post them then.
most spacers blow... I have seen hub-centric ones,, but the wheel isn't hub-centric after the spacer cause the spacers are flush.. so vibration and or the wheel coming loose is very possible... their pretty much an off road item...
Discussion Starter #7
Man I know spacers blow but I also like my rock warrior wheels just would like them to sit out a little more you know?
I got my 1.25" spacers off ebay (hub-centric also) - this was back in December, so I can't remember the name of the vendor. I did experience some vibration around 60-70mph, which would go away for awhile after a balance... but man, they really made a difference visually!
Discussion Starter #9
Are you saying there was a vibration then you had the tires balanced it went away then it came back?
hmmmm...sounds to me like if it vibrated, then went away when the tires were balanced then would come back, that its not a balancing issue and more of a wheel working its way "un centered" if you will....that the whole thing would be centered and vibration free at first but after a while would settle back to where it was off center, whether it was hub to spacer, spacer to wheel or whatever....masterdiag, does that make sense? how im describing it? i think thats the thought you are having too..
1 - 10 of 10 Posts
