1 - 7 of 7 Posts
2003 4x4 V8
Few years ago when I got the truck I lowered the rear with shackles 1". This made the rear still 1" higher than the front.
Which I liked since it was like my old 2000 V8 2wd model. Not as much wheel space about the tire.
Recently had a problem with it leaning. The shop said it was the front struts and replaced them with a TRQ strut.
Now it looks like the front is level with the rear or 1/4" higher.
Are there options to lower the front 1".
Thanks for any suggestions
Discussion Starter #2
In case it helps someone else.
SOS performance makes a 1" lowering kit. Can also custom make one to whatever you want. Still use the same spring and shock
I just started a post about this. I think my after market shocks have raised my front by about an inch. They were on it when i bought it. But no one else seems to talk about this issue, so i wasnt sure it was the shocks or what. Did you have any luck with this?
Discussion Starter #4
Yes the aftermarket TRQ shocks and springs raised my front and made it ride like crap. I ended up going back OEM. New oem springs and Bilstein 4600 shocks. The change lowered the front and made a huge difference. So much better.
If it helps. Now my front is 20 1/2" Measured from center of front wheel to the bottom of the fender
2003 Tundra 4x4 SR5 reg cab
Discussion Starter #6
how much did that cost you? OEM stuff is so expensive. But this look and feel is killing me.
I forget the total. But also my dealer told me I got the last set of oem coil spring in the US. One came from midwest the other had to come from west coast. Think total was about 800.00
Later I did find out on another forum there are a few places that make good aftermarket oem springs. But dont remember which companies. But they were cheaper. When I was looking at first I could only find springs that raised the truck. And not much help on this forum. But dont think I am allowed to post the other Tundra forum here.
Discussion Starter #7
If nothing else you could get oem springs from a online junk yard then new Bilstein 4600 shocks.
My springs where bad. But it seems that is rare.
1 - 7 of 7 Posts
