I am installing a set of PRG/Deaver 3 leaf mini-packs in an 07 Tundra. I have the overload spring removed, but can not get the little dowel pin out that helps line it up. Any suggestions on how it comes out? Thanks.
Discussion Starter · #2 ·
By the way, I have searched the forums and read the 20+ pages in the PRG/Deaver thread. My truck is half apart and any help would be appreciated.
I finally got them out. WD40, lots of squeezing and turning with a pair of channel locks. I even shoved the overload spring above the pin and hammered on it a little to get it started. That pin was in there tight.
Am I right that the torque on that center pin is 33 ft. lbs.?
send us some pics and comments on the results when your done. Sounds like an interesting project. Will it increase you carrying capacity?
