1: Open center console compartment (arm rest)
2: engage parking brake half way
3: lift up on the cup holder assembly around parking brake, it is just held in by pressure clips
4: unscrew 4wd shifter knob if you have 4wd
5: lift up on shifter surround (the big piece around the AT shifter and 4wd shifter)
6:the radio surround is also held in by just pressure clips, so, starting at the bottom, use even pressure to pull the center radio surround away from the dash, and disconnect all wires.
7: unscrew radio
hope this helps!
