Just looking for simple instructions to replace the bulbs - I am installing Sylvania Silverstar Ultras. Thanks!
They're easy to replace. The easiest way to get to them is by taking out the headlight housing. Just turn the bulb 1/4 turn and it should pop right out.
Good luck.
Don't know if it's all of them or not, but the OEM fog light housings that I installed over the weekend, had 3 screws holding in the bulb, which would require removing the housing from the bumper first to unscrew them...unless you can fit a screwdriver back behind the housing as installed.
