Hello all, I have a 2002 Tundra 2 wheel drive with 165k miles. I'm in the middle of the big brake upgrade and while the truck is lifted and the brakes are removed, I decided to spin the hubs and see how freely they moved. It appears that the driver side hub is quite a bit more stiff to turn than the passenger one. Is this something to be concerned about and what should I do?
Thanks for your help in advance.
Does the pass. side make noise when spinning it? Does it have excessive endplay or up and down movement? I would be more concerned about the one that spins freely. There should be some resistance from the bearing grease.
