41 - 47 of 47 Posts
The illumination circuit ground runs into the combination meter(gauge cluster). Poor engineering! If there is a short then a fuse should blow not your combination meter!
I had the same problem with my illumination lighting. I research the wiring diagrams from Toyota TIS and came up with a quick fix. I spliced into the illumination ground and ran a new ground point. Much cheaper then $850!!
Let me know if anyone is still having problems with the illuminations. I can foward you the wiring diagram and my quick fix.
Any chance on getting that diagram? Thanks!!
The gauge cluster (speedometer, tach, etc) all work as they are supposed to. The problem is in everything right of the steering wheel. None of the HVAC control lights come one, nor does the passenger side floor light, or the orange center console light for the cup holder area. The clock/temp/mpg shows when the lights are not on, but with parking lights or headlights on, where that display should dim, it turns completely off. Because of all of this, I am not suspecting a fuse, but am still suspecting its something from the dimmer wire (orange/white) on the radio wiring harness. I am not sure which wiring schematic to look for to trace it back, and see where it may have effected what systems. I have a copy of all wiring schematics for the truck, just a matter of finding it.
Hi @Whistlepig. Did you ever figure out what was causing the issue with the lighting for everything right of the steering wheel? I am currently having the same issue. The Clock, Outside Temperature, HVAC control lights, Orange center console light all go out as soon as the Headlights are turned on. Everything illuminates as normal with the headlights off. Wondering if you found a solution to this problem by any chance!
Thx!!
Hi Clevelandjac, is it possible to send me the diagram for this fix?
I would greatly appreciate it!! thx!
[email protected]
Javy
This is the diagram that was posted.
there is a wire harness behind it and in Pin #37 there is a red ground wire you need to splice into it and ground it again. See attached to see what the wire harness looks like and the pin placement.
151249
I applied this workaround fix. Worked perfectly thank you!!
I found a You Tube video that may help with dash disassembly to access the back of the cluster system
Javy
Just confirmed that the mosfet did the trick for my 2008 sequoia.
I ordered the same part that was stated on the celica site but used on my gauge panel. The MOSFET is on the back of the unit. NO NEED TO TAKE THE POINTERS OFF THE GAUGE PANEL.
Just remove the white cover on the rear of the gauge panel. Should be the same on a Tundra.
This was caused by me installing a new Pioneer radio and wiring the dimmer switch.
DO NOT WIRE IN ANY DIMMER wire to your Toyota. It's best to avoid this and control via the radio instead. Just my 2 cents.
Something else I noticed on My Sequoia. I had to wire the reverse trigger wire at the rear right of the sequoia. The trigger wire on a 2008 rear lamp is BLACK (go figure) as I thought it was ground. It is larger than the other wires in the area. You can easily access by removing the lower rear hatch cover.
Due to this short on the reverse circuit, I had to replace the Fuse box/ Junction box as it damaged some circuits. Bought the fuse box from Ebay and resolved all my issues.
Lesson learned!!!!! :)
Interesting... looks like your MOSFET is a 2SK1284. I wonder if that is due to higher load on the Sequoia because it have a higher voltage max. I ordered both 2SK1284 and 2SK2231. I'll see when I tear mine apart.
41 - 47 of 47 Posts
