Ok, for some reason, the factory has sent me too many crew max sr5s 2 wheel drives and I have even more of them coming.
So if you live in Nor cal or want to come to norcal to get one. $100 over factory invoice plus whatever incentives are available at the time the truck gets here. I will happily email you the vehicle inquiry report to show you what factory invoice is.
So if you want to take advantage of this, call or email me
Here is an example of one that I have in stock right now
18186 VEHICLE INQUIRY REPORT DATE: 05/11/07
DCV920 TIME: 12:21
Model Number: 8262A SERIAL # :7S456357 Check Code: 6
Model Description: CMAX SR5 5.7L V8 Category ..........: G
Year ............: 2007 Current Dealer ....: 120-04236
Interior Color ..: FC44 FC44 Wholesale Dealer ..: 04236
Exterior Color ..: 0040 WHITE Previous Dealer ...: 00120
Body ............: CMAX SR5 5.7L V8 Invoice Date ......: 04/14/07
Number of Cyl ...: 8 Ship Date .........: 04/18/07
Allocation Number: 031 Retail Date .......:
Engine Number ...: 5033496 Date of First Use .:
Vessel Number ...: 714 TRAC ..............: NO
Vessel Name .....: TMMI PRINCETON Damage ............: NO DAMAGE
PDI ...............: YES
Fleet .............: NON-FLEET
Port PDS Complete .: NO
VIN .............: 5TBEV54177S456357
Ignition Key.....:
Factory Installed Accessories: FE DZ BU MG OF SO
Port Installed Accessories ..: CF
Retail Dealer
Vehicle Base Model ....................: $ 30935.00 $ 27068.00
Total Accessories .....................: $ 2621.00 $ 2052.00
MECHANICAL & PERFORMANCE
GVWR = 7000 lbs. Payload = 1605 lbs.
381HP/401 Lb-Ft 5.7L DOHC 32V V8 w/VVT-i
6-Spd Automatic Trans w/Sequential Shift
Engine Immobilizer, Cruise Control
Tow Equip/Capacity: Tow Cap=10,400 lbs.
Hitch Receiver, Supplemental A/T
Cooler, 4.30 Rear Diff w/10.5" Ring
Gear, 150A Alternator, A/T Temp Gauge,
7 Pin Connector, Trailer Brake Prewire
Automatic Limited Slip Diff (Auto LSD)
TripleTech Frame: Fully-boxed Fr Section
Reinforced C Under Cab, Open C Under Bed
Coil Over Shock Double A-Arm Front
Suspension w/Stabilizer Bar
Multi-Leaf Trapezoidal Rear Suspension
w/Staggered Outboard Mounted Shocks
18" Styled Steel Wheels P255/70R18 Tires
EXTERIOR
Double-Walled Bed w/Tailgate Assist
Black Handles and Outside Mirrors
Chrome Grille Surround, Fr & Rr Bumpers
Pwr Vertical Rr Window w/Privacy Glass
INTERIOR
40/20/40 Front Bench Seat w/8-way Dr &
4-Way Fr Pass Adj, Center 3pt Seatbelts
Slide and Recline 60/40 Rear Bench Seat
Dual Zone Climate Control w/Sync Mode
AM/FM/CD w/6 Speakers & Aux Audio Jack
Tilt Steering Wheel
Power Windows/Door Locks/Mirrors
Remote Keyless Entry System
Variable Intermittent Windshield Wipers
SAFETY
STAR Safety: Pwr Assist 4 Wheel Disc ABS
w/Electronic Brakeforce Distrib (EBD),
Brake Assist, Vehicle Stability Control
with Traction Control (VSC+TRAC)
Dr & Fr Pass Advanced Airbags/Seat Side
Airbags/3 pt Seatbelts w/Pretensioners
& Force Limiters
Roll-Sensing Curtain Airbags (RSCA)
Tire Pressure Monitoring System
Retail Dealer Total
Vehicle Base Model ..........................:$ 30935.00 $ 27068.00 $ 30935.00
50 State Emissions .........................
AM/FM Audio w/6-Disc Changer, 6 Speakers ... 200.00 150.00
and Auxiliary Audio Jack ...................
Cloth Bucket Seats w/8-Way Power ........... 565.00 452.00
Adjustable Driver''s Side / 4-way ...........
Adjustable Passenger''s Side, Adjustable ....
Headrests, Tilt/Telescoping Steering .......
Wheel, Floor Shift Lever, Center Console ...
Box with Laptop and File Storage, Trip .....
Computer (Curr MPG/Avg MPG/Range/Temp ......
Gauge) .....................................
Front and Rear Mudguards ................... 60.00 48.00
TRD Offroad Package: Offroad-tuned ......... 1115.00 892.00
Suspension, Bilstein Shocks, Unique 18" ....
Alloy Wheels w/P275/65R18 BF Goodrich ......
Tires, Fog Lamps, Engine and Fuel Tank .....
Skidplates, Front Tow Hook, TRD Offroad ....
Package Graphics ...........................
Front and Rear Clearance Sonar ............. 500.00 400.00
Carpet Floor Mats w/Door Sill Protector .... 181.00 110.00
Total Accessories ...........................: $ 2621.00 $ 2052.00 $ 2621.00
Destination Charge ..........................: $ 645.00 $ 645.00
TDA .........................................: $ 541.00
Gasoline ....................................: $ 10.00
Dealer Holdback .............................: $ 618.00
Whsl. Financial Reserve .....................: $ 309.00
Total .......................................: $ 31243.00 $ 34201.00
Your price would be $31343 plus tax, title and $55 doc fee. Plus take special rates or an additional $1000 rebate
DCV920 TIME: 12:21
Ignition Key.....:
Retail Dealer
EXTERIOR
INTERIOR
Tilt Steering Wheel
SAFETY
& Force Limiters
Retail Dealer Total
