I have a desert sand 5.7L 4wd sr5 truck order get cancelled so here it is and for the time being is available. It is not due in until June so I can try to make some changes to it to get it closer to what you want. Just let me know. Price is $31794 plus tax and license. I dont know what incentives if any will be available in June yet so I wont speak on those. If there are any rebates at the time,of course you will get that too. This is the price just for the truck
18186 VEHICLE INQUIRY REPORT DATE: 04/22/07
DCV920 TIME: 12:42
Model Number: 8342A SERIAL # :7X22C207 Check Code: 8
Model Description: DCAB SR5 5.7L V8 Category ..........: A
Year ............: 2007 Current Dealer ....: 120-04236
Interior Color ..: FB44 FB44 Wholesale Dealer ..:
Exterior Color ..: 04Q2 DSND Previous Dealer ...: 00120
Body ............: DCAB SR5 5.7L V8 Invoice Date ......:
Number of Cyl ...: 8 Ship Date .........:
Allocation Number: 042 Retail Date .......:
Engine Number ...: Date of First Use .:
Vessel Number ...: 722 TRAC ..............: NO
Vessel Name .....: TMMTX SANANTONIO Damage ............: NO DAMAGE
PDI ...............: NO
Fleet .............: NON-FLEET
Port PDS Complete .: NO
VIN .............:
Ignition Key.....:
Factory Installed Accessories: FE BU CK DZ AA HM MG WR
Port Installed Accessories ..: CF
Retail
Vehicle Base Model ....................: $ 31160.00
Total Accessories .....................: $ 2428.00
MECHANICAL & PERFORMANCE
GVWR = 7100 lbs. Payload = 1580 lbs.
381HP/401 Lb-Ft 5.7L DOHC 32V iForce V8
w/Dual Independent VVT-i
6-Spd Automatic Trans w/Sequential Shift
Engine Immobilizer, Cruise Control
4WDemand 4x4 System w/Electronically
Controlled 2 Speed Transfer Case
Tow Equip/Capacity (Except when equipped
w/Sport Appr Pkg): Tow Cap = 10,300 lbs.
Hitch Receiver, Supplemental A/T
Cooler, 4.30 Rear Diff w/10.5" Ring
Gear, 150A Alternator, A/T Temp Gauge,
7 Pin Connector, Trailer Brake Prewire
Automatic Limited Slip Diff (Auto LSD)
TripleTech Frame: Fully-boxed Fr Section
Reinforced C Under Cab, Open C Under Bed
Coil Over Shock Double A-Arm Front Susp
Multi-Leaf Trapezoidal Rear Suspension
w/Staggered Outboard Mounted Shocks
18" Styled Steel Wheels P255/70R18 Tires
EXTERIOR
6.5'' Double-Walled Bed w/Tailgate Assist
Black Handles and Outside Mirrors
Chrome Grille Surround, Fr & Rr Bumpers
INTERIOR
40/20/40 Front Bench Seat w/8-way Dr &
4-Way Fr Pass Adj, Center 3pt Seatbelts
Dual Zone Climate Control w/Sync Mode
AM/FM/CD w/6 Speakers & Aux Audio Jack
Tilt Steering Wheel
Power Windows/Door Locks/Mirrors
Remote Keyless Entry System
SAFETY
STAR Safety: Pwr Assist 4 Wheel Disc ABS
w/Electronic Brakeforce Distrib (EBD),
Brake Assist, Vehicle Stability Control
with Traction Control (VSC+TRAC)
Dr & Fr Pass Advanced Airbags/Seat Side
Airbags/3 pt Seatbelts w/Pretensioners
& Force Limiters
Roll-Sensing Curtain Airbags (RSCA)
Tire Pressure Monitoring System
Retail Total
Vehicle Base Model ..........................:$ 31160.00 $ 31160.00
50 State Emissions .........................
Cloth Bucket Seats w/8-Way Power ........... 605.00
Adjustable Driver''s Side / 4-way ...........
Adjustable Passenger''s Side, Adjustable ....
Headrests, Tilt/Telescoping Steering .......
Wheel, Floor Shift Lever, Center Console ...
Box with Laptop and File Storage, Trip .....
Computer (Curr MPG/Avg MPG/Range/Temp ......
Gauge) .....................................
Cold Kit: Heavy Duty Battery, Heavy Duty ... 100.00
Starter, Heavy Duty Anti-Corrosion .........
Protection, Windshield Wiper De-icer .......
w/Timer ....................................
AM/FM Audio w/6-Disc Changer, 6 Speakers ... 200.00
and Auxiliary Audio Jack ...................
18" Alloy Wheels w/P275/65R18 Tires ........ 910.00
Power Heated Outside Mirrors ............... 30.00
Front and Rear Mudguards ................... 60.00
Sliding Rear Window w/Privacy Glass ........ 345.00
Carpet Floor Mats w/Door Sill Protector .... 178.00
Total Accessories ...........................: $ 2428.00 $ 2428.00
Destination Charge ..........................: $ 645.00
TDA .........................................:
Gasoline ....................................:
Dealer Holdback .............................:
Whsl. Financial Reserve .....................:
Total .......................................: $ 34233.00
DCV920 TIME: 12:42
VIN .............:
Ignition Key.....:
Retail
EXTERIOR
INTERIOR
Tilt Steering Wheel
SAFETY
& Force Limiters
Retail Total
