Does anyone know the dimensions of the 2010 Double Cab Rear Seat, Underseat storage box that is built in at the factory?
:ts:
:ts:
Unless things have changed, this is an option that is not standard equipment (mine is a 2009 which should be the same box). The option was priced at around $15, but if you add it on later, its about $100 (TRD-Sparks for the win!!!, my dealer wanted $145 + tax)
Now here's the details...
The box is shaped like a U with two compartments, separated by a small divider. The space is roughly 60/40 (the split of the rear seats). The overall useable length is about 55" across the top, by approximately 12" wide. The attached photos should give you some real-world expectations (tape-measurement included)
Hope this helps.
