I'm installing an after market Kenwood DNX6140, into a 08 Tundra that had only an CD/Radio, does anyone know where the wiring is located in the dash for the back up camera?
Also, how do you do the bypass?
NC
You will need to tap the wires that are running down the drivers side a-arm. Remove the oh-**** handle and pull the trim piece off. You'll see 2 harnesses. One of them will have all the following wires on it.
White brings ground to the camera
Black brings supply voltage to the camera
Red is video positive
Grey is video negative
This is assuming you use the stock camera and wire it into your aftermarket HU. Search for more detailed info.
