Hi,
I just bought a 2010 SR5 Sequoia with 8 speaker (non-JBL) stereo. I've already installed the navigation system (Kenwood DNX9140) but am having trouble trying to locate a reverse wire for the backup camera. I have the base model without the factory nav prewiring, so there is not a reverse wire where the radio system was. I've already tried looking it up in the techinfo.toyota.com site, but haven't succeeded. Does anyone know where I can find the reverse wire lead.
Thanks,
Alex
You can use the reverse wire from the trailer hitch, but keep in mind that you might want to install a diode (or something similar) t prevent a surge. Not sure if you actually need it, just pointing it out as a possibility.
Thanks Mike. My subscription to the Toyota site had lapsed. Do you know which color wire is the reverse in the trailer hitch?
If you look at the 7 pin cover, it is labeled to tell you what pin is what. Good luck and post some pics when you're done!
