Almost 6 six years driving my Tundra and this is the first problem I've had. Consider myself lucky. But left home yesterday and one minute later, my gauges and signal lights quit. Checked the manual and there is no one fuse (or relay?) that controls both. Advice?
Nope, everything is good to go. It's a strange combination I must say. For now, I'm going to start testing anything that has the instrument panel listed as on the circuit. Hopefully I'll find it that way. Thought it might be a problem or situation someone had run across before. But thanks for the suggestion!
I would check fuse(s) and relays no matter what the book says. Start with the easiest solution first. It is also possible you lost a ground wire somewhere. There are locations on the truck that have multiple grounding wire points. If one of those loosened or fell of it could be the cause. Good luck!
