Let me start off with saying, Hi! My name is Jeremy, and I live in Ocala, FL. Ive been in and around the Automotive field my entire life (literally), and hope to contribute at least as much to the forum, as I've gotten (through lurking, lol)
Ive done all the searching I can, as well as tons & mega-tons of diag work, and cant figure this one out. Rough Idle on cold start up (about 50% of the time), within minutes, it runs great. Intermittently, it will begin to stumble/shutter at low RPMS/Idle. Whether it is in gear or not has no bearing. Even drove it around for 2 days with the scanner connected, hoping to see a sensor hiccup. It does NOT have any codes, Pending or otherwise, and everything in the data stream appears good(temp snsr, MAF Snsr, misfire monitor, etc).
It is a 2002 Tundra Limited, Access Cab, 2wd, Automatic, 4.7L V8- 226,xxx miles
Things Done-(in no particular order)
Throttle Body & Gasket (First cleaned TB, then replaced)
Denso Iridium Plugs (it needed them anyway)
1 Coil Pack (Didn't like the resistance values on it, so I replaced it)
Mass Airflow Sensor (Cleaned first, no change, then replaced, still no change)
Oxygen Sensors (All 4- At one time it was setting codes for the 2 that commonly go bad, replaced all 4 anyway)
Edit:I forgot to mention I also sprayed the intake down with carb cleaner both when the stumble was happening, and when it was not. There was no difference in the way it ran, nor any changes to Oxygen Snsr readings
Later this evening I am replacing the fuel filter, because it has been about a year since last replacement. I find it incredibly unlikely that this will help with the problem, but the preventative maintenance must soldier on!
Thanks in Advance
Thanks in Advance
