1 - 10 of 10 Posts
Alright guys n gals. The day has finally come!!! JBA is finally finished with our long tube headers!!!
I gave them the last set that we made years ago to copy. In return I get to introduce them to the world. And I get the very first set:)
Here’s some info:
3/8" thick laser-cut flanges
Firecone® merge collector technology
Mandrel-bent stainless steel 1-5/8" primary tubes
Premium quality hardware included
2.5" collector
Optional ceramic coating (thermal barrier)
360 degree welds
Oversized exhaust ports
We will be building mid pipes to go along with these headers. And a dual race catback system. The mid pipes can use no cats. Magnaflows. Metallic high flows. Or your cats. (Just send them to us). The catback will be able to exit before the rear tire passenger side. One before each rear tire (2wheel drive only). Dumped under truck. Or tie into your existing dual
These will fit 00-04 without air injection. But..... I may have an easy solution to make em work with air injection. As you can see the holes are there. So maybe we will weld em shut;)
Jba has 20 sets in stock. 10 Bare. 5 silver (one of which is mine) and 5 titanium. When these are gone the next sets will have the holes plugged up to block the air injection.
With air injection blocked you will want a Hewitt tech module to shut down the system. Call for
Details.
760-877-4234
That is really cool. I installed the JBA shortys on my 02 tundra 4.7. What is involved when installing these. Welding?
Sweet!, what is the price on these? I was looking at Stan's headers, and would like to get a pair soon. Thanks for all your work on these!
I assume they would fit a sequoia fine?
Will these not fit a 2006? I don't know if physically the vvt changes the way the exhaust bolts up or if it's an issue of the wrong port or some bracket or something. Headers short or long might be nice because I have a leak somewhere up there anyway and power is always good.
Are these California legal? How hard to install?
1 - 10 of 10 Posts
