2006 Tundra DC 4wd with 240k miles on her
This is my wife's truck - her pride and joy to drive - so, since I don't drive it every day, I may be missing some information.
The truck will start and drive in a normal fashion and these symptoms came on one day, seemingly without warning.
The symptoms:
*Battery will hold a charge but the alternator is not charging the battery - when the engine is revved above 2000 rpm the battery needle waivers but it stays down below the middle mark.
*Dash lights lit - ABS 4HI 4LO
*Brake lights and blinkers are inop - but the headlights and hi-beams work as well as the hazard lights
*Seat heaters inop
*Electric seat adjustments inop
*Bed light inop
*Radio inop
*Wipers inop
*Windows inop
I've checked each of the fuses with a multi-meter.
One 7.5 amp fuse was blown in the engine bay labeled RSE (rear seat entertainment) - replaced.
The battery has been removed from the truck, cleaned and charged - the terminals have been cleaned as well.
Is the alternator bad and all these other symptoms are pointing to that?
OR, is the alternator part of the symptoms as a whole that point to a different problem?
Input is greatly appreciated, if it's not constructive at least let it be entertaining.
I'll be here rubbing my chin and scratching my head.
The symptoms:
*Seat heaters inop
*Bed light inop
*Radio inop
*Wipers inop
*Windows inop
