I recently installed JBA Headers about 2 months ago because I had a tapping sound with a ping. The tapping noise is still present at ALL Times, the ping is very noticable durring hard acceleration between 2000 - 3000 rpm. I looked at many sites on this forum and many posts referenced craked or warped manifold(s). Therefore I immediately had the Headers installed earlier than planned.
When my mechanic installed the Headers he used the old locknuts from the manifolds (all except one). I was told it was better to use the old lock nut's rather that the bolt's that came with the Headers. Is there a possibility that the old lock nut's when tightened did not draw all the way. I was talking with a friend of mine who also is a mechanic and has worked on many toyota's and he said your best off not to use the old lock nut's becase sometimes they don't draw in all the way even if you think their tight.
1. Does anyone have a method that I can use to determine if these things are leaking? My mechanics assistant re-tightened the headers with out a torque wrench and he said there they were tight as a drum and no leaks. Which I am skepticle because the darn truck wasn't running! But they were in a big hurry and the head mechanic (who has treated me very well for years) only charged me a $100 for the install so I didn't want to be a pain.
2. Is it possible to get some stainless washers and replace one bolt at a time with the washer to ensure they are truly tight and in fact the Headers are drawn in? Or should I simply get all new lock nut's from toyota and replace them one at a time? Not sure of the cost but it can't be that bad.
3. If there is a leak would it mean the Header gasket is junk and should I get the metal gaskets from Toyota?
I honestly feel that there is some loss of power. If infact the Headers are leaking would there be a loss of power?
Any and all suggestions would be greatly appreciated, this has been going on for 6-8 months and it is driving me up a wall. I would like to attend the truck dyno run in New England in March that V8toilet posted but the way my truck is running right now I would be embarrassed to no end!
