In my Double Cab, I was running wires for an amp, and I decided to remove a bolt on the passenger side rear seat to see if it would allow the back of the seat to fold down. I can put the bolt back in only with the bottom of the seat raised, and then the bottom of the seat won't go back down. The tension is gone from the handle as well. Any help would be greatly appreciated!
Discussion Starter · #2 ·
Update: I was able to get the seat bolted in the down position but the seat won't go back up with the bolt in. The wire that connects to the handle on the bottom/side of the seat is bent slightly which probably has something to do with all this too I'm guessing.
