KSPORT's Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. Made from high quality 6061 Aluminum with T6 for increased hardness.
Kontrol Pro
•36 levels of adjustable damping
•Made from high quality 6061 aluminum with T6 for increased hardness
•Compression/Rebound adjustable
•Adjustable spring perch for height adjustment
•Adjustable body allowing maximum suspension travel
•Pillowball top mount with adjustable camber (not available for some models)
•Monotube high pressure design reduces oil leakage
•Electroplated body for protection from corrosion and rust
•One year limited warranty
Avalon - 1995 ~ 1999 - XLS - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Camry - 1992 ~ 1996 - - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Camry - 1997 ~ 2001 - MCV20L - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Camry - 2002 ~ 2006 - - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Camry - 2007 ~ 2011 - - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Celica - 2000 ~ 2006 - ZZT231 - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Uses Rr OEM Mount
Celica - 1990 ~ 1993 - GT, GTS, SX ST184/ST182 - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Celica - 1994 ~ 1999 - AT100/ST202/203/204 - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Celica - 1994 ~ 1999 - AWD / Super Strut ST205 - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Celica - 1994 ~ 1999 - Non Super Strut ST202/203 - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Celica - 1994 ~ 1999 - Super Strut ST202/203 - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Celica - 1990 ~ 1993 - AllTrac, GTFour ST185 - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Corolla - 1998 ~ 2002 - ZZE110 - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Corolla - 1983 ~ 1987 - AE86 - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Corolla - 1988 ~ 1997 - AE92,AE11,AE101 - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Corolla - 2003 ~ 2008 - ZZE130L - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Uses Rr OEM Mount
Corolla - 2009 ~ 2012 - Rear Integrated - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Uses Rr OEM Mount
Corolla - 2009 ~ 2012 - Rear Separate - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Uses Rr OEM Mount
Echo - 2000 ~ 2005 - SCT10/NCP12L - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Uses Rr OEM Mount
MR2 - 1985 ~ 1986 - AW11 - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
MR2 - 1987 ~ 1989 - AW11 - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
MR2 - 1990 ~ 1999 - SW20 - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
MR2 - 2000 ~ 2005 - Spyder ZZW30 - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Paseo - 1991 ~ 1995 - L4 - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Alum Top Mnt
Paseo - 1996 ~ 1999 - L5 - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Alum Top Mnt
Prius - 2003 ~ 2009 - NHW20 - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Uses Rr OEM Mount
Prius - 2010 ~ 2012 - - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Uses Rr OEM Mount
Starlet - 1985 ~ 1999 - EP70/EP81/EP92 - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Alum Top Mnt
Supra - 1987 ~ 1992 - JZA70/MA70 - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
Supra - 1993 ~ 2002 - JZA80 - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
Tercel - 1995 ~ 2000 - - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Alum Top Mnt
Yaris - 2005 ~ 2011 - - Height/Ride Adj - 36 dampening levels - Uses Fr OEM Mount / Uses Rr OEM Mount
GT Pro
•Inverted steel shock absorber for durability
•Lower center of gravity and higher chassis rigidity
•Designed to reduce friction for cooler shock oil temperature
•Inverted design like vehicles in WRC and all JGTC cars
•36-way adjustable damping
•Made from high quality 6061 Aluminum with T6 for increased hardness
•Adjustable spring perch for height adjustment, •Adjustable body allowing maximum suspension travel
•Pillow Ball Top Mount w/ adjustable camber (not available for some models)
•Monotube High Pressure Design reduces oil leakage
•One Year Limited Warranty
Celica - 1994 ~ 1999 - AT100/ST202 AT100/ST202 - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Celica - 1990 ~ 1993 - GT, GTS, SX ST184 - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Corolla - 2009 ~ 2012 - - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Uses Rr OEM Mount
Yaris - 2003 ~ 2011 - Sedan - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Uses Rr OEM Mount
Rally Spec GR (Gravel) or Rally Spec AR (Asphalt)
•Special designed springs for rally conditions
•Extended Piston Stroke
•Reinforced internals to withstand extreme track conditions
•Compression/Rebound adjustable, Adjustable spring perch for height adjustment
•Pillowball top mount w/ adjustable camber (not available for some models)
Celica - 1990 ~ 1993 - GT, GTS, SX ST182 - For Asphalt - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Celica - 1994 ~ 1999 - ST202 - For Asphalt - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Celica - 1994 ~ 1999 - Weld-in Required Superstrut ST202/203 - For Asphalt - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Celica - 1990 ~ 1993 - GT, GTS, SX ST184 - For Asphalt - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Celica - 1990 ~ 1993 - AllTrac, GTFour ST185 - For Asphalt - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Celica - 1994 ~ 1999 - AWD - Weld-in Required ST205 - For Asphalt - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Corolla - 1998 ~ 2002 - ZZE110 - For Asphalt - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Corolla - 1988 ~ 1997 - AE92,AE11,AE101 - For Asphalt - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Echo - 2000 ~ 2005 - SCT10/NCP12L - For Asphalt - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Uses Rr OEM Mount
Paseo - 1991 ~ 1995 - L4 - For Asphalt - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Alum Top Mnt
Paseo - 1996 ~ 1999 - L5 - For Asphalt - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Alum Top Mnt
Supra - 1987 ~ 1992 - JZA70/MA70 - For Asphalt - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
Supra - 1993 ~ 2002 - JZA80 - For Asphalt - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
Tercel - 1995 ~ 2002 - - For Asphalt - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Alum Top Mnt
Yaris - 1999 ~ 2005 - - For Asphalt - Height/Ride Adj - 36 dampening levels - Uses Fr OEM Mount / Uses Rr OEM Mount
Celica - 1990 ~ 1993 - GT, GT-S, SX ST184 - For Gravel Ralley - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Celica - 1990 ~ 1993 - All-Trac, GT-Four ST185 - For Gravel Ralley - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Celica - 1990 ~ 1993 - ST182 - For Gravel Ralley - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Celica - 1994 ~ 1999 - AT100/ST202 - For Gravel Ralley - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Celica - 1994 ~ 1999 - 2wd Non Turbo ST204 - For Gravel Ralley - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Celica - 1997 ~ 2002 - ST215 - For Gravel Ralley - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Corolla - 1998 ~ 2002 - ZZE110 - For Gravel Ralley - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Corolla - 1988 ~ 1997 - AE92,AE11,AE101 - For Gravel Ralley - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Version RR
•Aggressive valving and spring rates
•Race applications only
•Pillow ball top mount w/ adjustable camber (not available for some models)
Celica - 1990 ~ 1993 - GT, GTS, SX ST184/ST182 - For Road Racing - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Celica - 1994 ~ 1999 - AT100/ST202/203/204 - For Road Racing - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Celica - 1994 ~ 1999 - AWD / Requires Weld-in ST205 - For Road Racing - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Celica - 1994 ~ 1999 - McPherson ST202/203 - For Road Racing - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Celica - 1994 ~ 1999 - Requires Weld-in ST202/203 - For Road Racing - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Celica - 1990 ~ 1993 - AllTrac, GTFour ST185 - For Road Racing - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Corolla - 1998 ~ 2002 - ZZE110 - For Road Racing - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Corolla - 1988 ~ 1997 - AE92,AE11,AE101 - For Road Racing - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
MR2 - 1985 ~ 1986 - AW11 - For Road Racing - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
MR2 - 1987 ~ 1989 - AW11 - For Road Racing - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
MR2 - 1990 ~ 1999 - SW20 - For Road Racing - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Paseo - 1991 ~ 1995 - L4 - For Road Racing - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Alum Top Mnt
Paseo - 1996 ~ 1999 - L5 - For Road Racing - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Alum Top Mnt
Supra - 1987 ~ 1992 - JZA70/MA70 - For Road Racing - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
Supra - 1993 ~ 2002 - JZA80 - For Road Racing - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
Tercel - 1995 ~ 2002 - - For Road Racing - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Alum Top Mnt
Slide Kontrol
•Inverted shock design (Most applications)
•Optimally designed for larger wheel/tire combinations
•Utilizes helper springs in the rear to increase stability and traction
•Heavy duty internals to withstand abuse
•Inverted Monotube high pressure design reduces oil leakage
Celica - 1994 ~ 1999 - Requires Weld-in ST202/203 - For Drifting - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Celica - 1994 ~ 1999 - AWD / Requires Weld-in ST205 - For Drifting - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Corolla - 1983 ~ 1987 - AE86 - For Drifting - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Corolla - 1983 ~ 1987 - Type III AE86 - For Drifting - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
MR2 - 1985 ~ 1986 - AW11 - For Drifting - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
MR2 - 1987 ~ 1989 - AW11 - For Drifting - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
MR2 - 1990 ~ 1999 - SW20 - For Drifting - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
MR2 - 2000 ~ 2005 - Spyder ZZW30 - For Drifting - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Supra - 1987 ~ 1992 - JZA70/MA70 - For Drifting - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
Supra - 1993 ~ 2002 - JZA80 - For Drifting - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
Version DR
•Valved and sprung for drag racing; Proven to reduce 60 ft and elapsed times
•Includes shock dyno results, and tuned to your needs
•Adjustable spring perch for height adjustment, Adjustable body allowing maximum suspension travel
•18 Month Limited Warranty
Paseo - 1991 ~ 1995 - L4 - For Drag Racing - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Alum Top Mnt
Paseo - 1996 ~ 1999 - L5 - For Drag Racing - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Alum Top Mnt
Supra - 1993 ~ 2002 - JZA80 - For Drag Racing - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
Tercel - 1995 ~ 2002 - - For Drag Racing - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Alum Top Mnt
GO TO NOPI KSPORT Catalog for model specific images and details
Contact the salesmen below or PM me for our best deal on KSPORT Coilover Systems
