good morning!
i have started changing over the stock incandescent lights to l.e.d.'s. the one issue ive run into is, the tail/brake lights blowing a fuse when installing them. how many fuses are there for the tail/brake light system any way?!
apparently, there are more than one and the one that blew, is hidden away somewhere that i couldnt find! so, what is causing the fuse to blow when installing the l.e.d. bulbs and where is this hidden fuse?
when i did the swap on my '07 tundra, the only lights i didnt swap over were the signals. i wasnt too concerned about doing them as they worked fine. not to mention, i wasnt a big fan of the heat generated by the resistors.
any help, suggestions or insight would be appreciated.
lee
lee
