1 - 17 of 17 Posts
Just got a new 2010 Tundra, and I need some advice on a lift. I think I have narrowed it down to the OME, or the ToyoTech adjustable coil overs, or should I spend the money and go with a 6"er from Procomp. I would use it as a daily driver, but I also go hunting and cross creeks, make hard turns where the suspnesion binds up. I only want to run 33's. If I went with the 6" lift, would I look retarded with 33"s.
I want to run some 33" muds, and I have only seen the tires in a 295/70/r18 instead of the 295/65/r18 (BFG and Toyo). If I run the 295/70 will they rub when the suspension is bound up in a full turn with the 3" lifts from above?
Someone can chime in here on the tires, but the 295/75/18s is what I want to run. They should look fine on a 6" suspension lift.
I personally would do the OME or the Toytec before beating on a suspension lift that's 6" that's not solid front axle.
I went with the OME and it looks and rides great and was quite a bit cheaper than the Toytec... around 450 shipped vs about 900 (right?).
Ah, and just for reference, the 295/75/18 is just around 34.5"
-rockstate
OME.....love it, no regrets, great ride and handles the bumps perfectly....
do OME,stay away from spacers!!!"not bashing them,so dont beat me up" 33" tires would fit,and look good to,with no binding at full lock.285/65/18,would be the best fit,with no rubs.
I'm running teh 285/65/18s and had tem when I was stock. No problems whatsoever. Great size for a stock truck, looks small on a lift. It won't really rub unless you're going to be stuck first haha.
-rockstate
-rockstate
true to a point,if you have a plus off set with 285s will looked good,but if you get a stock fitment,or plan on using your stock rims,it will look a little small,but like he said,if your stuck bad enough,you can get your stock tires to rub!!lol
Personally, I wanna run the 295/70/18s next time around. 34.5" or so and it'll look baller. I just need to find out FIRST whether or not I can do it on stock offset, stock rims (no prob), but with 2.5" lift lol
-rockstate
-rockstate
ya,you can fit those,maybe a little rub at full lock if your cought in a pickle.lol "stuck,on a hill,or whatever else crap we get into when out wheeling.lol"
True. I want those tires. the Trailgrapplers look BA. They're about $260 a tire though on 4wheelparts.com or whatever website is similar to it.
The Terra Grapplers are only 230 a tire. Price matched locally of course (already talked to 'em)
-rockstate
i have the trail grapplers,LOVE THEM,but on 90% of the trucks i lift here,i go with the terra,they last FOREVER,not loud,dont vibrate,over all an awsome tire!!!!
Discussion Starter · #14 ·
How do you guys like the icon coil overs. Just saw them yesterday, and I think I have found my target. How much extra wheel travel do you get over stock on those bad jimmys. Does BFG or Toyo make a mud terrain tire in a 285/65/r18? If not who does. I also noticed that the Rock Warrior rims are 17", can I put on 17" rim on my 2010? If so I know that both BFG and Toyo make a tire that I want.
just so everybody knows,ICON IS AWSOME!!!!LOL
up to 4" in the front,and 2"in the rear.
1 - 17 of 17 Posts
