I recently purchased a used 2007 double cab. The truck is level at all four corners. Other than this fact, how could I tell what kind of method was used to level it out?
It sounds like it was just a simple leveling kit. All you need to do is look and see if there is a spacer above your coil spring.
and just a spacer doesnt really tell you much either. its is a spacer inside the strut assembly against the coil spring or is it a spacer bolted to the top of the strut like mine. if its bolted to the top is it a truxx/readylift steel version or is it a billet aluminum type? :) not that it really matters, they all do the same thing and each version has their fans that swear by them.....
