1 - 15 of 15 Posts
...Raptor Slayer...
Just a thought but has anyone tried to run a 2" or 3" lift spacer and an adjustable coilover and run the coilover at 1" to gain the same ride height i guess to dampen or soften the coilover. I dont know what it would hurt if your keeping it at about the same 3" lift right. The only problem i could think of is the coilover top mount not mounting to certain spacers or bolt length. :noidea:
There is a guy from Arizona who did something off thebeaten trail. He did it to get 4 inch lift I think his name is Daniel Acosta he is on TS.
Sounds to me like itd be a waste of some cash brotha.
I would assume the coilovers would be way more than sufficient in ride even at 3" lift.
Why put a bandaid (not even a butterfly bandaid) on something when you need stitches, and are getting stitches.
Just my opinion.
-rockstate
...Raptor Slayer...
Discussion Starter · #11 ·
im just trying to think how to get the most Droop not travel out of the front suspension without going to camburg LT and spending $8 to $10 G's you know
You will only break something if you're jumping this thing and using it to its full potential.
Just take what you can afford but don't cheapen up a set of $1300 shocks by putting a spacer on.
-rockstate
...Raptor Slayer...
Discussion Starter · #13 ·
-rockstate
ya jumping over 5 rotating helicopters and through fire hoops
1 - 15 of 15 Posts
