Pins 13 and 14 are auto dimming at the mirror.
also, where do you plug in at the kick panel?Pins 13 and 14 are auto dimming at the mirror.
Congrats. Wayne, glad you got yours working! :tu: Pins 13 & 14 at the mirror connection control the auto dimming. One thing I found on my Tundra, once I had the new mirror connected to the harness; before adding pins, I experimented by removing two of the blue connectors one at a time. I would remove one plug and I'd loose the turn signals, plug it back in and unplug the one above it and I'd have the turn signal back but no power adjustment. Your wiring harness at the kick panel is different than mine. I'll have to run wires from the female side to the JL1 connector, but in your case you had all the wires there, a difference between a deluxe with the SR5 option and a regular/cremax SR5 model.thanks Jim, I also got the folding mirror to work today. do you know where wires go at kick panel for the auto dim and puddle lights? I know some people wired the puddle lights to the foot light by the hood release but just wondering if anyone else figured out where the wires actually go into the cluster wires/connectors? i meant it would be easier to wire to the foot light but i am not big fan of having puddle lights come on when turning on the interior lights (flipping the switch).
what are the puddle lights that you are referring to ? I just bought limited mirrors and Im curious what your calling puddle lights.
On the driver side, the auto dim wires go to the same connector as the power fold wires. The wires at the mirror (pins 13 & 14) go to pins 5 & 6 at the kick panel. On the passenger side, the auto dim wires go into a different harness than the power fold. The power fold go into the bottom connector and the auto dim wires go two above that. The wires at the mirror (pins 13 & 14) go to pins 6 & 5 on that connector.
Check out Sparks Toyota TRD Toyota-Scion Performance Parts Accessories from Sparks Toyota-Scion go to the OEM parts section and search. Price was not bad, cheaper than your local Toyota dealer. If you don't have the memory package on your rig don't get the switch with it. The part listing will give several choices, just choose the one you need.where did you get your switch and is it the one without memory apparently found only in the platinum? but where did you get it and how much $
