I have a loaded crewmax in slate coming in the end of May. Discounted down to $45001 plus tax , doc and license. Call me if you are interested
18186 VEHICLE INQUIRY REPORT DATE: 04/01/07
DCV920 TIME: 11:11
Model Number: 8372A SERIAL # :7S18A789 Check Code: 9
Model Description: CMAX LTD 5.7L V8 Category ..........: A
Year ............: 2007 Current Dealer ....: 120-04236
Interior Color ..: LB13 LB13 Wholesale Dealer ..:
Exterior Color ..: 01F9 SLATE Previous Dealer ...: 00120
Body ............: CMAX LTD 5.7L V8 Invoice Date ......:
Number of Cyl ...: 8 Ship Date .........:
Allocation Number: 033 Retail Date .......:
Engine Number ...: Date of First Use .:
Vessel Number ...: 718 TRAC ..............: NO
Vessel Name .....: TMMI PRINCETON Damage ............: NO DAMAGE
PDI ...............: NO
Fleet .............: NON-FLEET
Port PDS Complete .: NO
VIN .............:
Ignition Key.....:
Factory Installed Accessories: FE CK EY AL KG MG NV SO SR
Port Installed Accessories ..: CF
Retail
Vehicle Base Model ....................: $ 41850.00
Total Accessories .....................: $ 6236.00
MECHANICAL & PERFORMANCE
GVWR = 7200 lbs. Payload = 1495 lbs.
381HP/401 Lb-Ft 5.7L DOHC 32V V8 w/VVT-i
6-Spd Automatic Trans w/Sequential Shift
Engine Immobilizer, Cruise Control
4WDemand 4x4 System w/Electronically
Controlled 2 Speed Transfer Case
Tow Equip/Capacity: Tow Cap=10,100 lbs.
Hitch Receiver, Supplemental A/T
Cooler, 4.30 Rear Diff w/10.5" Ring
Gear, 150A Alternator, A/T Temp Gauge,
7 Pin Connector, Trailer Brake Prewire
Automatic Limited Slip Diff (Auto LSD)
TripleTech Frame: Fully-boxed Fr Section
Reinforced C Under Cab, Open C Under Bed
Coil Over Shock Double A-Arm Front Susp
Multi-Leaf Trapezoidal Rear Suspension
18" Alloy Wheels w/P275/65R18 Tires
EXTERIOR
Cargo Bed w/Deck Rail Sys, T/gate Assist
Color-keyed Fr Bumper/Chrome Rr Bumper
Chrome Grille/Door Handles/Outer Mirrors
Pwr Vertical Rr Window w/Privacy Glass
Fog Lamps
INTERIOR
Leather Trim Pwr Heated Front Buckets
Center Console w/Laptop & File Storage
Slide and Recline 60/40 Rear Bench Seat
Auto Dual Zone Climate Cntrl w/Sync Mode
JBL AM/FM 6-CD, 12 Spkrs, Aux Audio Jack
Pwr Tilt/Tele Strng Wheel w/Audio Cntrls
Power Windows/Door Locks/Mirrors
Pwr Memory Seats/Outside Mirrs/Strng Whl
Remote Keyless & Anti-Theft Alarm System
SAFETY
STAR Safety: Pwr Assist 4 Wheel Disc ABS
w/Electronic Brakeforce Distrib, Brake
Asst, Veh Stability Cntrl w/Trac Cntrl
Dr & Fr Pass Advanced Airbags/Seat Side
Airbags/3 pt Seatbelts w/Pretensioners
& Force Limiters
Roll-Sensing Curtain Airbags (RSCA)
Tire Pressure Monitoring System
Retail Total
Vehicle Base Model ..........................:$ 41850.00 $ 41850.00
50 State Emissions .........................
Cold Kit: Heavy Duty Battery, Heavy Duty ... 100.00
Starter, Heavy Duty Anti-Corrosion .........
Protection, Windshield Wiper De-icer .......
w/Timer ....................................
Rear Seat DVD Entertainment System with .... 1670.00
Rear Seat Audio System, 2 Wireless .........
Headphones and Wireless Remote, 115V AC ....
Outlet in Center Console ...................
20" Alloy Wheels w/P275/55R20 Tires ........ 920.00
Running Boards ............................. 345.00
Front and Rear Mudguards ................... 60.00
DVD Navigation System w/Backup Monitor, .... 1650.00
JBL AM/FM w/4-disc Changer, 12 Speakers ....
including Subwoofer, 8 Ch 440W Amplifier, ..
Bluetooth Capability, Steering Wheel .......
Audio Controls and Auxiliary Audio Jack ....
Front and Rear Clearance Sonar ............. 500.00
Power Tilt and Slide Moonroof .............. 810.00
Carpet Floor Mats w/Door Sill Protector .... 181.00
Total Accessories ...........................: $ 6236.00 $ 6236.00
Destination Charge ..........................: $ 645.00
TDA .........................................:
Gasoline ....................................:
Dealer Holdback .............................:
Whsl. Financial Reserve .....................:
Total .......................................: $ 48731.00
DCV920 TIME: 11:11
VIN .............:
Ignition Key.....:
Retail
EXTERIOR
Fog Lamps
INTERIOR
SAFETY
& Force Limiters
Retail Total
