1 - 8 of 8 Posts
Go here and order these in 4 ft lengths. Waterproof Ribbon LED Strips Attach them to the bed rails so they point down. Connect the wires to the bed light wiring (the light at the top of the cab). You have to go inside the cab, down to the plastic strip at the bottom of the door, to find the wires. then when you turn on the bed light the whole thing lights up. Piece of cake.
How do I ID the cargo light wire?
Buy your leds from ebay! Cheap and very good light output
Right, you have an 05 so that elec diagram should work. look for the black wire with a white stripe going to the cargo light. Use a volt meter to ensure you get 12v when you turn on the cargo light and zero volts when you turn off the cargo light. You don't need a relay with the led strips from Oznium, they will only pull like a quarter of an amp each. And Oz will exchange them if one or two leds are bad. On ebay, its a maybe for customer service.
1 - 8 of 8 Posts
