1 - 17 of 17 Posts
After reviewing several level kits, I think I have decided to go with LRO. However, I am concerned when the company states that with 200lbs in the bed, the bed is completely level. I have a Sungtop cap on my truck which I'm sure weighs more than 200lbs. This means without putting anything in the bed the rear would be sagging. I often have a good bit of gear in the bed and don't want to have a sagging rear.
I'd love to hear others thoughts, experiences, or alternatives.
Thank you!
Stephen
I ran that kit for a year and a half. Thru two winters I had 360lbs of sand in the bed and the truck still had a slight forward rake to it. Id highly recommend the kit.
mhollack,
Did you ever have more than the sand bags in the bed? What are your thoughts if there was 800-1,000 lbs in the bed?
pic of my truck with LRO towing a 1,200 lb trailer and 4K lb jeep... the truck did not really sag at all. looks level.
Guys, what you're forgetting here is that not all trucks are equal... and you'll see a difference between trucks, and especially miles.
My truck with a set of Jeep doors in the rear, and about 25 other lbs of random junk makes it sit "nose high" without a block. My truck has 50K miles on it, so the rear shocks have a lot more play in 'em.
A one inch block should be good for more than 200 lbs though.
That is like 1/4 of a cord of wood I believe. Probably somewhere in that range of 800-1000 lbs.
I believe I had about 1.5-2" of sag
-rockstate
This is very true. I have a 3 inch lift kit and my truck still sits nose high with 1 inch blocks in the back.
Thank you for the responses. So, what are the options to avoid a "nose high" situation with a 3/1 LRO kit?
Airbags or an add a leaf, or a heavier duty leaf pack. Alcan makes some and you can also get a set of the Old Man Emu leafs (I believe they use Dakar or something)
-rockstate
Or you could always use a 2inch,or whatever is needed lift block. Axle wrap could be an issue if more than 2 is used. If you cant source them online check out metal surplus places they can cut you whatever you need high grade billet aluminum is what your after. Good luck
i'im not sure, but I knkow that particular hoscks such as the 5100s and OMEs are rated for like 1-3" (I think) of lift.
-rockstate
I dont think you need to worry about it - put the LRO kit on and give your applicantion a try first before going to additional measures.
I'm with miked on this one. Just get the kit on there and see how it does.
get airbags in the rear....adjust the height to whatever you want
That's what I'm gonna do. I'll just order the front lift since I already have Firestone Air Bags in the rear. For a 4x2 it is $80 less than the complete kit and LRO is taking only phone orders for this since it is not a regular kit.
1 - 17 of 17 Posts
