I've always changed my diff fluid with syn and additive every 5k to 15k and at 75k it has made noise when turning is it possible to rebuild the clutch plates. This winter it had one wheel wonder so I know its not working yet sqeels the tires in a black top parking lot at slow speeds and everytime I turn from a stop . It ha s130K and Im worried it may explode!
So is there hope of rebuilding it or is it time to search junk yards?
I believe you can rebuild it. Check your local dealer or contact TRD directly. Not sure on the cost but, it may cost you a bit.
try doing some figure 8 at slow speed for a while slowwly in a lot
what modifier did you use
Drain and refill will the ford modifier and do the figure 8 in a lot
see if that helps
