Hey to all, About to install Bilstein 5100's on a 2013 SR5 Double cab 4wd. Was wondering if anyone had measured before and after ride height? example my truck right now with TRD standard Yellow shocks sits at 36 1/2" in the front and 39" in the back, no lift kit.
Any one that has installed and left the setting at the lowest level on the front and then the back with no spacers/lift kit. thanks in advance, CSM-H
Discussion Starter #2
So you know, I installed the rear Bilstein 5100's and there is NO change in ride height in the rear. Hopefully the fronts will be installed tomorrow, professionally and I will answer that question also for those who may want to know. CSM-H
Hey to all, again. Finished the install of the 5100's. ride height in front as advertised, just 1" on bottom "clip"... Truck ride is firm, but better. Well worth the money to install.... Just do it, you won't disappointed. CSM-H
