Here's the deal. The Sequoia needs to go in for an oil change this week. Since the Toyota dealers in my area are all terrible, a private garage (good reputation, years of experience) that I actually used to work at when I was a kid does the work. He only charges $10 labor to change the oil and filter with the Mobil1 and filter that we supply. I have 7 quarts of Mobil1 75W90 and planned on having the fluid changed in the front, center and rear differentials when the oil change is done.
Called the mechanic to schedule the appointment and he's questioning "messing" with the differentials and claiming it's not necessary as they are filled from the factory with synthetic. After explaining that Toyota uses conventional fluids, and restating the desire to change the fluid out for Mobil1, he said to check with the dealer to see what they advise. He seems afraid to do it, and keeps trying to make the point that it is un-necessary. My point is that once the fluid is changed over to Mobil1, it's pretty much lubed-for-life at that point and on less thing to worry about.
I can't see what the big deal is. I'd crawl under there myself and do it, but now that winter has arrived I am not inclined to do so.
