Looking for some help with XD/KMC Monsters. I know some of their wheels come with two patterns drilled in them. Found a good deal for a set of 22" Monsters on a 2008 Dodge 1500. The seller is a good disctance away so a dry fit isn't exactly easy. Does anyone know if the same wheel has the 5x150 pattern drilled into them? and if the backsping will work?
I haven't had any luck trying to search both trucks on rim sights in an attempt to match model numbers.
Thanks in advance.
