Hey guys, new to the site. Having trouble identifying a breather hose on my 06 tundra dc 4x4. I have 3 breathers on my drivers side wheel well. One of them is not attached to anything currently and I can’t for the life of me figure out where it goes.
In the picture the red is a larger diameter and goes to the front diff, the yellow is smaller and goes to the ADD actuator. The mystery blue breather is also smaller diameter and is not attached to anything currently. It’s rather short as it ends at the top of the cv axle currently, so I’m not sure if it got cut or something.
Any help would be greatly appreciated!!
154078
Pipe Iron Fuel line Rust Steel
Check to see if it goes to either the transmission or the transfer case. That would be where I would look. Your rear diff breather is just a check valve on top of the axle so it won’t be that.
See if it goes to the transfer case shift actuator. I’m pretty sure it has a breather. I think I had to fix mine right at the actuator about 6 years ago. Been a long time so my memory is a little foggy
