I'm havin a hell of a time finding black wheels 18x9 to fit on a 2010 with a Procomp 6" lift. I'm told I have to have 4.5" or less backspacing to keep 35x12.5 from rubbing.
What are you guys using with this lift?
David
Dont know if it helps much (and you may have known this already) but it basically means you want a -11 offset or lower.
Perhaps someone can do a full explanation of OFF SET and Back Spacing.
I googled my *** off for that! Thank you!! While I did understand it and do even better now... my question is the same. I'm trying to find a flat black 18x9 rim -12mm offset (4-4.5" bksp) in a 5x150... I was wanted the Pro Comp 7047 but they only come in 0 and +12mm offset... Not sure if that HALF inch will cause rubbing or not. Seems like all of the Xtreme rims for a Tundra are 5-5.5". I like the Monsters but they're listed as 5.53" "Blank", are about $100 out of budget and seems they're one @ least a 30 day backorder everywhere. I was getting the 7047s @ $140 each in the pkg... was trying to stay in that range.
David
I think I just found my rims!!! Eagle 197 Super Finish/Black 1972-9923. 18x9 5x150 -11mm 4.5"... and they are about $160! These with some Toyo Open Country MTs in 35x12.5x18 should work well on 6" Stage 1 me thinks! :clap:
David
