Hey guys.
I have a 2002 Tundra SR5 with the factory optional P265/70R-16 tires and was looking into some new wheels.
I really like the wheels Enkei made for the XSP Tundras but know they are hard to find. So I went to Enkei's site and found some similar looking ones you can find anywhere, the RT6 models. I even downloaded the diagram from their site to see if they had my bolt pattern and bore diameter. They do, a 6x139.7 bolt pattern and 108mm bore diameter, Enkei part number 25229083SM. These are the 20 inch ones, which are listed as having a 12 on the offset for all the wheels of the style in that size. Yet another site claims to have them with a 0 offset Or a 12 offset. That site is: Buy 20x9 rims enkei rt6 wheels Machined w/ Silver color. enkei rt6 20x9 machined w| silver wheels at WheelsNext.com
My question is, can I get these rims and the tires one site recommends for them, a 265/50/60 and they still fit on my truck? Would I need to get a 12 or (if it exist) 0 offset?
Or would the 20 inch rim not fit at all and the biggest I could get be a 18 inch wheel? I know the 18's have a 0 offset. I'm not really sure exactly what offset or backspace is and wonder if it would cause a problem with my truck.
I have attached the PDF from Enkei on the RT6 wheels to show the specs on them as well as this site that further explains their specs: Enkei 25229083SM - Enkei RT6 Silver Wheels - Overview - SummitRacing.com
I see that all of the RT6 Rims are not hub centric and wonder if this would cause a problem as well?
Thanks, I know this is a weird/complicated one. I would really appreciate the help.
-Jeff
-Jeff
