I'm going to replace the rotors, pads and maybe the calipers on my 2002 Tacoma S-Runner (4x2). Since I don't have a manual I need to know what the torques specs are for the bolts that hold the rotor and caliper. Any help will be appreciated.
when ya take bolts out check torque values as ya remove them? possibly could get the correct values by seeing where they break at, just try tighetning them to start and start with low torque and work your way up like 5ft lbs at a time? maybe someone will find info before ya tear into it!!I'm going to replace the rotors, pads and maybe the calipers on my 2002 Tacoma S-Runner (4x2). Since I don't have a manual I need to know what the torques specs are for the bolts that hold the rotor and caliper. Any help will be appreciated.
I've been at another parts store and checked the aftermarket manuals. They don't have one for my year yet and it just isn't printed yet. Since there are 5 bolts that hold the lug bolt plate and the rotor on I want to make sure I have the torque valves to avoid causing any chance of warping the new ATE slotted performance rotors.when ya take bolts out check torque values as ya remove them? possibly could get the correct values by seeing where they break at, just try tighetning them to start and start with low torque and work your way up like 5ft lbs at a time? maybe someone will find info before ya tear into it!!Just go to Pep-Boys and borrow a manual on their shelf for about 5 minutes! You being a subscriber shouldhave access to this info? what gives?
I looked but haven't found anything. last time I looked the Toyota manual would cost me as much as the entire brake job.I believe if you search the knowledge database you might find the torque values. That's how I found all the torque specs for my front suspension when I installed my Donahoe's.![]()
