Hi all,
I'm installing a Hidden Hitch on my 2005 xB. I finally found a lift I can use. I have been quoted from $60 w/o wireing by a local grease monkey to $350 by my (former) favorite dealer. Turned out my (still) favorite son-in-law has a lift I can use after hours.
I am lookin for the wire color code for the tail lights so I can do as little damage as posible, those wires are thin!
TIA:ts:
John
If you just want running and brake lights without turn signals, buy a universal trailer wiring harness and connect it to a tail light wire. But to have turn signals, an adapter module is required because the universal U.S. trailer harness is 4-wire and the car is European 5-wire.
The European 5-wire system has wires for:
left turn
right turn
running lights
brake lights
ground
The U.S. 4-wire system has wires for:
left turn/stop light
right turn/stop light
running lights
ground
The converter module can be gotten here or from a NAPA store:
http://www.acehardware.com/product/index.jsp?productId=1288819
Also check out http://www.hitchsource.com/ for modules and connectors.
If you haven't already gotten your hitch, try etailers.com. I just ordered a curtis hitch and the T-One connector for my new Venza for $196 + free shipping. The T-One connector with tail light module and wiring to the battery $54 - makes the install very easy.... I did it on my 06 RAV 3 years ago... the entire install (hitch and wiring) took 30 minutes w/o a lift
