· Vendor
Form Lighting is excited to introduce our new Sequential LED Headlights for the 2007-2013 Toyota Tundra and 2008-2017 Toyota Sequoia!
The 07-13 Tundra and 08-17 Sequoia are both workhorses, so it’s no surprise to see so many still on the road. However, the halogen lighting is dated and leaves a lot to be desired on output. A full LED upgrade with headlights from FORM Lighting is a great way to modernize your truck and provide the performance you need.
Modern Styling. These headlights feature the newer styling found on premium trim levels of the 2018+ Sequoia, with added features such as sequential turn signals. The newer styling is a great way to refresh the look of your truck and give it a serious update.
Full-LED Output. These headlights feature full LED function, including low beam and high beam. Using modern, application-specific optical reflectors, these lights produce much higher intensity and output than the factory halogen units.
High-Power DRL. The most distinctive part of these headlights is the integrated LED daytime running light, or DRL. This illuminates when your truck is running, with a brilliant and noticeable white LED accent. Even though the factory headlights don’t have DRL, installation of this feature is simple thanks to the included fuse box wire harness.
Sequential Turn Signal. These headlights feature an integrated sequential LED turn signal. Every time the turn signal is activated, amber LEDs flash across the middle of the lamp in a smooth, chasing sequence. When you’re finished making your turn, they automatically “switch back” to the bright white DRL.
Bolt-On Installation. Even though the headlight style changed over the years, these lights bolt right on the factory mounting points. The only difference is a small trim panel that goes under the headlight. A pair of trim panels are included with your purchase, which you can either wrap in vinyl or paint to match your truck.
OEM-Grade Construction. Form Lighting headlights are built with quality in mind, using OE-grade materials and design techniques. This includes durable UV-coated polycarbonate lenses, automotive-grade LED emitters, breather vents, and OEM plug-and-play connectors. They are assembled in an IATF 16949-certified facility, which is a quality management system designed for the automotive industry. While they may not be the cheapest option you’ll find, you can rest assured that these lights will provide durable and superior performance.
Road Legal. Form Lighting headlights meet all SAE, DOT, FMVSS, and CMVSS standards and regulations for legal on-road use in the United States and Canada, when installed and aimed properly - which is easy to do with the integrated screw-type adjusters.
Plug-and-Play. Our headlights for the Tundra and Sequoia are plug-and play for the main functions, along with a fuse box wiring harness if you’d like to enable the daytime time running light feature. They were designed to plug into your factory headlight connector and work correctly with the factory electronics. No errors, flickering, or hyperflashing!
Click the video below to see HOW to install our 2007-2013 Toyota Tundra and 2008-2017 Toyota Sequoia Sequential LED Headlights!
Two-Year Warranty. All Form Lighting products are rigorously tested for reliability, and backed by a two-year warranty. The warranty is supported directly by Form Lighting, and any replacement parts, if needed, are shipped quickly from Form Lighting’s US warehouse. In the rare occasion that you may need to utilize your warranty, we try to keep the process as simple as possible - for example, no return is normally necessary.
Do you have additional questions? We’ll be happy to help!
• Reply to this thread
• Send us a direct message
• Email: [email protected]
Are you a US forum member? DM us for a FREE shipping code!
Jordan M.
Form Lighting
· Vendor
Discussion Starter · #2 ·
Jordan M.
Form Lighting
Prime Day savings are here! Ends midnight CST, 10/12/22.
NOW through 10/12, you can get 10% off at our Amazon store for Prime Day!
No coupon required.
This discount will be automatically applied.
Click HERE to visit the FORM Amazon store!
· Vendor
Jordan M.
Form Lighting
Our Black Friday Sale is here, and that means it’s time to save!
Now through 11/29, you can get 15% OFF FORM Lighting storewide!
No coupon required.
This discount is automatically applied.
CLICK HERE TO SAVE AT THE FORM STORE!
· Vendor
Jordan M.
Form Lighting
LAST CHANCE for 15% off LED headlights for your Tundra or Sequoia! Form Lighting's Black Friday Sale ends TONIGHT!
No coupon required.
