As you know, the 2014-2021 Tundra is a highly capable truck. However, one particularly weak point is the factory halogen headlights. Although Toyota did eventually start providing LED headlight options in 2018, conversion requires re-pinning connectors and adding additional harnesses. Now, there’s a simple solution available that improves both visibility and appearance. Introducing full-LED Reflector and Projector Headlights from FORM Lighting!
Click HERE to check out our 2014-2021 Toyota Tundra Reflector LED Headlights!
Click HERE to check out our 2014-2021 Toyota Tundra Projector LED Headlights!
Projector Model. The main upgrade with the Projector option comes with the bi-LED projector unit. This assembly shines light with a sharp cutoff, wide spread, and high intensity, for a huge improvement in visibility on the road. It acts as the main light source for both low beam and high beam, for an excellent improvement in both functions.
Reflector Model. If you’re looking for that factory styling and quality, this is the solution for you. The Reflector model was inspired by the factory LED styling, and provides a big improvement in output from the full-LED low beam and high beam reflectors. They pack a few extra features as well.
Modern DRL. A distinctive line of LEDs borders the top and bottom edge of these lights, with custom optics. This provides a premium, modern appearance, and extra safety on the road. If your truck didn’t come with DRLs, no worries! A simple wire harness is included to connect to the fuse box, to activate your DRLs any time the vehicle is running.
Sequential Turn Signal. The DRL isn’t the only thing that stands out. These headlights also feature an integrated sequential LED turn signal. Every time the turn signal is activated, amber LEDs activate across the top and bottom of the lamp in a smooth, chasing sequence. When you’re finished making your turn, they automatically “switch back” to the bright white DRL.
OEM-Grade Construction. Form Lighting headlights are built with quality in mind, using OE-grade materials and design techniques. This includes durable UV-coated polycarbonate lenses, automotive-grade LED emitters, breather vents, and OEM plug-and-play connectors.
They are assembled in an IATF 16949-certified facility, which is a quality management system designed for the automotive industry. While they may not be the cheapest option you’ll find, you can rest assured that these lights will provide durable and superior performance.
Road Legal. Form Lighting headlights meet all SAE, DOT, FMVSS, and CMVSS standards and regulations for legal on-road use in the United States and Canada, when installed and aimed properly - which is easy to do with the integrated screw-type adjusters.
Plug-and-Play. Our Projector and Reflector Headlights for the Tundra are plug-and play for the main functions, with multiple connectors for each function that plugs right into the factory wiring harness. A fuse tap is included if you’d like to enable the daytime time running light feature. They were designed to fit perfectly, and bolt right up without any gaps or interference. No errors, flickering, or hyperflashing!
Automatic Leveling. One unique feature incorporated into the stock headlights is Toyota’s electronic headlight leveling system. Our lamps were designed to retain this useful feature. Right out of the box, each headlight includes its own leveling motor that is compatible with this system. The factory connector plugs right in, and you can still use the factory adjustment knob inside the truck.
Two-Year Warranty. All Form Lighting products are rigorously tested for reliability, and backed by a two-year warranty. The warranty is supported directly by Form Lighting, and any replacement parts, if needed, are shipped quickly from Form Lighting’s US warehouse. In the rare occasion that you may need to utilize your warranty, we try to keep the process as simple as possible - for example, no return is normally necessary.
Do you have additional questions? We’ll be happy to help!
• Reply to this thread
• Send us a direct message
• Email: [email protected]
Are you a US forum member? DM us for a FREE shipping code!
Jordan M.
Form Lighting
