Recently purchased new tires for my 2003 4x4 Tundra and proceeded for an alignment; my last tires didn't wear very well. Told the mechanic I wanted a printout of the existing alignment and a post printout of the new alignment using DJ's specs.; by the way, to DJ and others; thanks for for sharing your knowledge on this board; it's appreciated much. The one thing that came from the shop's work was the toe and total toe were done in inches so I'm not sure if they are close to DJ's specs. Anyway; here's the pre and post alignment numbers: Purchased Michelin LTX which are pricey; hopefully this alignment is correct. Does anyone know what the "inch" measurements convert to in "degrees"? Also, I noticed that my Tundra tends to drift to the right when I remove my hand; if I move over to the left lane it will drift slightly left; is this related to the " crown" of the road? Thanks for any help.
Pre: L caster 1.8 degs. R caster 1.5 degs.
L. camber -0.3 R camber -0.3
L. toe 5/32" R toe 1/16", total toe=3/16"
Rear L camber -0.2 R rear camber 0.1
Rear L toe -1/16" R rear toe 3/32"
Thrust angle -0.2 degs.
Post align: L caster 2.0 degs. R caster 2.0 degrs.
L camber 0.3 degs. R camber 0.3 degs.
L toe 1/32" R toe 1/32
Total toe 1/16"
Rear L camber -0.2 degs. Rear R camber 0.1 degs.
Rear L toe -1/16" Rear R toe 1/16"
Thrust angle -0.1 deg.
Total toe 1/16"
