1 - 11 of 11 Posts
I finally went around and some new Goodyear Wrangler Silent Armor LT285/70R17 on the Stock Wheels and had a little bit rub on the front fender. I cut off just enough so i could drive it without rubbing. I was wondering how some people trimmed there fenders. I used a dremel and a jig saw but it doesn't seem to cut the plastic more or less just burn through leaving a nasty looking cut. I just want to clean up that cut so it is not an eye sore. Thanks for the help.
Andrew
What clip position do you have your front 5100's on?
Have you checked your clearance between your upper control arm and the inside of your sidewall? That may be an issue also. Your 285's are just a little more than a 1/2 inch taller than my 275's I am running but I have no rubbing issues. Guess that 1/2 inch finds the limit so to speak...Sucks because there is a much bigger selection of 285's vs the 275's I am running.
Discussion Starter #5
I have the 1.25" spidertrax wheel adapters and have about 3/4" of space in between. that was the first thing i checked because if there was rub there i would be in trouble.
Andrew
Andrew
So there is no way you could have run the 285's without the spacer and clear the upper control arm? Guess the 275's are the limit then without spacers on the stock 17's.
Moderator
Andrew
I have used a simple file to clean up plastic cuts. Don't know if that will work for you but it might be worth a try.
Discussion Starter #8
i don't think you could with the stock wheels
I will probably give that a try, thanks
Andrew
I ran 285/75R16 tires on my OEM alloys before I put the lift on with no rubbing on the control arm.
I used a razor blade to trim my fenders, it put the plastic like butter.
Discussion Starter #10
Ah never thought about a razor blade, thanks.
Andrew
yeah i generally use a dremel to make the cut then a new razor blade to clean things up works great
1 - 11 of 11 Posts
