1 - 16 of 16 Posts
Im looking to purchase some wheels/tires and have noticed a lot of people have had issues with rubbing. I have a 2007 Tundra double cab with a 2.5in lift and Im looking to see if I can run a 275/65/20 (34.5in tall). Any feedback or pics of other Tundras with a similar setup would be helpful, thanks.
:wedgie:
see how helpful these people are on this website..if i knew i'd tell you. To think these people want us to donate to them. HA
...Raptor Slayer...
i run a 35x12.50 hancook 2.5 inch lift no rub stock rim but go to a tire shop they will be able to tell you and fit it especially if you get aftermarket rims
Ill be nice even though the answer is readily available if you search...the answer is yes, those fit quite easily with a 2.5" lift. The tires are basically the same width as stock, just taller, so you wont have any issues. Probably wont even need to trim the skidplate.
"These people" must not refer to me because I could care less who you give money to.
says the guy who called everyone ****.
Another good one Johnny! At least he made a post on someone else's thread. Although, it didn't really contribute anything....
I have that size tire in the Nitto Terra Grappler and I had to trim the skid plate as it rubbed when turning fully. I have the Toytec
3" lift. Took about 2 minutes with tin snips.
With a little skid plate trim you'd probably be fine. I got a toytec 2.5"/1" lift and run whats basically 34" tires with no problems, i could have gone bigger.
Wow you went back and dug this one out....
1 - 16 of 16 Posts
