1 - 13 of 13 Posts
Hello everyone, I am new here and ready to go for a new 2010 4x2 CM LTD. I think I have a good deal lined up but could use a double check by you all.
This is what I am looking at It has most of what I need how does this offer sound.
YOUR QUOTE: 36,497 after rebate ($3000 or the speacil rates through 2/1/10)
5.7L iFORCE V8 DOHC 32V Dual Independent
VVT-i 381HP/401 lb-ft and ACIS
6-Spd Auto w/Seq Shift and Tow/Haul Mode
GVWR = 7000 lbs. Payload = 1570 lbs.
Tow Equip/Capacity: Tow Cap=10,400 lbs.
Hitch Receiver, Supp A/T Cooler, 4.30
Rear Diff w/10.5" Ring Gear, 150A
Alternator, A/T Temp Gauge, 7 Pin Conn,
Trailer Brake Controller Prewire
Engine Immobilizer, Cruise Control
TripleTech Frame: Fully-boxed Fr Section
Reinforced C Under Cab, Open C Under Bed
Automatic Limited Slip Diff (Auto LSD)
Front and Rear Sonar
Coil Over Shock Double A-Arm Front Susp
Multi-Leaf Trapezoidal Rear Suspension
18" Alloy w/P275/65R18
SAFETY
STAR Safety: Pwr Assist 4 Wheel Disc ABS
w/Electronic Brake-force Distrib (EBD),
Brake Assist, Vehicle Stability Control
with Traction Control (VSC TRAC)
Dr & Fr Pass Advanced Airbags/Seat Side
Airbags/3 pt Seatbelts w/Pretensioners
& Force Limiters
Dr & Fr Pass Knee Airbags
Roll-Sensing Curtain Airbags (RSCA)
Tire Pressure Monitoring System
EXTERIOR
Double-Walled Bed w/Tailgate Assist
Deck Rail System w/4 Adj Tie-Down Cleats
Pwr Vertical Rr Window w/Privacy Glass
INTERIOR
Leather Trim Pwr Heated Front Buckets
Slide and Recline 60/40 Rear Bench Seat
Automatic Dual Zone Climate Control
JBL AM/FM/MP3 6-Disc CD Chgr, 12 Spkrs,
Aux/USB Input, Sat Radio 90-Day Trial,
Steering Wheel Audio Cntrls, Bluetooth
Power Windows/Door Locks/Mirrors
Remote Keyless & Anti-Theft Alarm System
Manual Headlamp Adjust
50 State Emissions .........................
20" Alloy Wheels ...........................
with P275/55R20 Tires ......................
Power Memory Package .......................
Power Driver Seat Memory, Power Outside ....
Mirrors with Memory and Puddle Lamps, ......
Power Tilt and Telescoping Steering Wheel ..
with Memory ................................
DVD Navigation System ......................
w/JBL AM/FM/MP3 4-disc Changer, 12 .........
Speakers including Subwoofer, Backup .......
Monitor, Bluetooth, Steering Wheel Audio ...
Controls, Integrated Satellite Radio w/3 ...
Month Free Subscription to XM Satellite ....
Radio and NavTraffic, Aux/USB Input ........
Daytime Running Lamps ......................
Power Tilt and Slide Moonroof ..............
Carpet Floor Mats w/Door Sill Protector
Back from the dead!
I have had an F350 Dually, didn't need a 1 ton but my needs did require a 3/4 ton. I have a Jayco 308FBS (34 foot) TT which is 7250lbs dry and the Tundra wasn't getting it done.
Nice, if I owned an F-350, this is what it would look like...
End thread jacking!!!! :embarrassed3d:
Congrats - I hope it's a great truck for your needs. Mine have changed. Here's my new truck
Need some beefy tires on that thing, i tow a 9K toyhauler when its fully loaded and have never had a problem even going through the rockys i was passing cars in spots but then again a half-ton to a super duty is not a comparasin at all. Turbo diesel vs. gas. Hahaha
1 - 13 of 13 Posts
