Nitto Ridge Grappler | A Fresh Look on Hybrid Light Truck Tires
Nitto's New Hybrid Light Truck Tire
The Nitto Ridge Grappler combines the aggressive off-road performance of a mud-terrain tire with the on-road comfort of an all-terrain tire. Using its aggressive tread design, tread block stabilizers, and variable pitch tread pattern, the Ridge Grappler delivers excellent traction in mud, sand, and loose gravel and a surprisingly responsive, comfortable highway ride. High load carrying capacities from P-metric up to F-rated options. Whether you drive a daily work truck or an off-road adventure vehicle, the Nitto Ridge Grappler is a great choice.
UTQG: N/A
Click here for: Nitto Ridge Grappler Availability and Pricing
-KEY FEATURES-
  • Variable Pitch Tread Pattern: Advanced sound equipment was used to create a pattern that provides a quiet and smooth highway ride.
  • Alternating Shoulder Groovers: Shoulder grooves are arranged in alternating widths and lengths to clear mud and maintain traction. Lateral Z grooves are set in a zig-zag pattern to provide biting edges for traction.
  • Dual Sidewall: Like all Grapplers, the Ridge Grappler features two bold sidewall designs. One side features a more traditional pattern while the other side features a new, aggressive block design.
  • Reinforced Block Foundation: Adds rigidity to tread blocks to reduce flex.
  • Stone Ejectors: Protects the bottom of groove from stone drilling.
  • Staggered Should Lugs: Provides traction in off-road environments.
  • Edges: The alternating tapered edges and step block edges both provide additional biting edges for more traction.
-MEDIA-
-INSTALLED PHOTOS-
-FUTURE SIZES-
Source: NittoTire
Do you know if the 35/11.5-20 will fit on the stock 20" Texas Edition wheels? I want to say my wheels are 8.5" wide but cant find any info on them.
Discussion Starter #4
Thank you for the post, Sr5racha-
Your factory wheels are 8-inches wide with a +50mm offset. The 35x11.50R-20 size is safely run on 8-inch to 10.5-inch wide wheels :tu:
